Heres some pics..
Have installed After market 700 hp Fuel pump and Oil Cooler As well Dont know what else to do...
autodan7 said:Have a 05 232 6.2L Procharger 5 psi with Intercooler...1.65 Bravo Drive Was running 13 7/8 23p Vengence 5100 to 62 on Gps Before procharger...Tried a mirage plus 15.5 25p to 4800 at 61 gps hole shot and mid range is Incredible..2000 rpm to 4500 Is as quick as it can be.... Can pull two skiers up with 8 people 2 coolers and alot of beer...But my top end sucks...Top end is why I installed the charger to begin with...One more note: at 4800 Is only 65-70% throtle More throttle does nothing and revs up and down 100 rpm like it is hitting the rev limiter. Guessing tach may not be right Installed procharger last fall did not run till this summer.... Looking At a smaller dia. mirage (Dont think I have the upper end torque to spin a 15.5 dia. prop) or Some other kind of speed prop Any suggestions... 62-63 mph Stock.. believe should be able to get to 70 or better What am I doing wrongAny advise would be greatly appriciated...
Not an expert at all on superchargers but it sounds like you are running out of air on the top end, I've chased this problem on my carbed motor, wait I'm still chasing it, but I was actually thinking about installing a procharger on mine but was afraid of the added complications, good luck! Let us know what you find
Danny
