1 - 4 of 4 Posts
I put a 500hp in my 22ft advantage and it has no t stat. I ordered the water crossover and the t stat housing from Eddie Marine and wanted to know if i am supposed to run this motor with or without a T stat. Thanks Jeff.
Horsepower Junkie
I would run a 140 high flow stat. But if you have water pressure issues then you will have to run a restrictor. You should be fine with the high flow version though.
Discussion Starter · #3 · (Edited)
Is that why it doesn't have a t stat now, for more water flow. I am not sure what temp the T stat is that Eddie Marine is sending me in the kit. What temp should my 500hp run at.
Horsepower Junkie
not running a t-stat or circ pump can cause steam pockets to form in the back of the heads. I would drill your intake (rear water ports)if you don't run one.
140-160 is a good range to run (non efi)
1 - 4 of 4 Posts
