1 - 6 of 6 Posts
I want to put a lab finished prop on my 22 Advantage. I have a 500hp with the only mod being a water crossover. I wanted to know what rpm i should run this motor at WOT for best results and if my rpm will change up or down with a lab finished prop.
speediseverything said:
Is there a rule of thumb that it will raise my rpm's when i go to the lab finished prop. 50,100. etc.
I would say generally 200 rpm is "average" but you can ask for more or less on certain props.
Is there any place better than the other to get my prop lab finished.
You will get different opinions on this but I don't think you can go wrong with Throttle Up or BBlades.
1 - 6 of 6 Posts
