Which one would you choose and why? 502 Mag has 415 hp and open cooling, 496 Mag HO has 425 hp and closed cooling. Besides that, what is the good and bad of these two engines?
cfm for acceleration I would agree. But for top speed it would SEEM that similar motors(ci and rpm range) the higher hp motor would have more top speed. But then again I am no expert!cfm said:blackhawk - probably another case where peak hp does not tell you everything.
My guess without seeing the dyno sheets is the 496 has more "ZING."
That's just it if anything according to dyno sheets they are over-rated.DagaH2X said:When I was shopping for a 288 it seemed on average the 496ho boats were 2-3 mph faster then the 502 boats. It seems to me maybe the 496ho is underated but thats just opinion based on what I know about motorswhich isnt much....
If it had the exact same torque and hp curve!cfm said:Would a NA 350cid with 435hp go as fast in the same size boat ?
Zing baby.![]()
I like it! Next time someone askes me how much HP I have im gonna tell em......not sure but it sure has some ZING huh...? :laugher:cfm said:
Zing is a new word I use to differentiate a motor that is faster than another even if they dyno at same power on the same dyno.
Zing !!!!
Isn't the 502 and 454 made from the same block? I don't see the weight savings.dallasboats.com said:
Why 502, Go 454 MAG, lighter and great revs, change the exhaust and you've 502 power output plus you save 100 + lbs.
NO !!!!!cuda said:Isn't the 502 and 454 made from the same block?
My 502 Mag longblock was $100 CHEAPER than the 454 Mag longblock. Guess I screwed up. I shoulda bought the 454.cfm said:Dallas - really not trying to step on toes but a 454 385HP Mag over a 502Mag ?
It's not weight. It's not power.
Only thing I can think of is price. other than that, take the 502 everytime.
My 02
