96 baja 272 bravo 1 speedo not working
1100 Views 4 Replies 4 Participants Last post by  Rock Steady
speedo works if u pull it out of the drive and feed presure up in line but does not work in the water ?????
thanks i will look for the water pick up u say it is in the front of the drive
1/8" drill bit should fit. I always do it by hand.
mm
How deep should the drill go in the drive before hitting aluminum?
(I have the same problem)
This happened all the time with mine, finally I gave up and got a GPS speedo.
But everyone is right, small drill bit, blow it out with the speedo tube disconnected, if there is a way for you to blow air down from the connection it would be best, that way you don't force anything up the hole any further.
