1 - 4 of 4 Posts
Anybody have trouble doing this First I had to grind a screwdriver to fit in the hole and then I broke the blade trying to turn it and it won't turn and will not idle below 1500 rpm
I fixed the idle problem, there is an allen screw that controls the opening on the secondary butterflies you have to back that off to get the secondary butterflies to close all the way. The middle idle screw is closed from the factory when you turn it, it will bring the idle up.
1 - 4 of 4 Posts
