before
you mean blow thru ? next year you will be ready for paint, or are you satisfide with the job ?levie17 said:Never used a buffer, not hard to do at all. Just have to keep it moving and not put too much pressure on.
The only real problem I had were the spots on the boat where the gel was real thin. You can see it in the first two pictures. I tried to avoid hitting those with anything.
Yes i did mention the blow thru , put as long as you are happy that's all that matters :winker:levie17 said:Yeah, did you tell me about the blow thru? As soon as I touched it, it started bleading blue. Gonna need paint for sure on that stripe next year. Gonna start saving...
Your boat might be a bit different... everything but the base color (off-white) is paint, not gelcoat - meaning you likely need to be a bit more careful if you have to wetsand.jrapp said:That looks great! I have some of that to do once I get the boat back from the shop. Did you use a buffer before this? If not was it hard to learn?
KJO...I am going to start a new thread as not to hijack, it is coming along...slowly.kjo43 said:Your boat might be a bit different... everything but the base color (off-white) is paint, not gelcoat - meaning you likely need to be a bit more careful if you have to wetsand.
Hows the progress coming?
