1 - 3 of 3 Posts
Just wanted to get some ideas on this, ever since I replaced the wood on my trl it floats, really aggrivating in the current where I launch, Ive been told to drill some holes in the center of the board any other ideas?
Bolt or strap on some lead weights, maybe from a dive weight belt or old anodes?
Does the trailer have guide posts? If you don't use them, consider putting them on under the trailer for the weight?
Add another piece of aluminum tube for "support"...
PVC tube filled with sand, capped off, and zip tied to the rear cross member or a couple attached to each of the i-beams at the rear. Been there.
1 - 3 of 3 Posts
