1 - 4 of 4 Posts
pump is toast. located it under the engine of course could they make less accessible. well im trying to trace the wires back that way to much of a hassle to many wires under there has anyone just sniped the two wire to the old one and crimp them to the new pump is that possible. just looking for a little input thanks.
If I`m understanding you - that would be ok, but as with any marine wiring, solder all connections and definately use heat shrink !
Make sure you splice them far enough up that they will never get into the bilge water, mine are up 24"! If they do you may short out. I used solder and the liquid tape. I then attached them to a stable spot out of the bilge waters possible highest level .
1 - 4 of 4 Posts
