Do you still run the stock bypass? There should be one in the pump and one in the filter housing thing.
Depends on who installed it,,, just look at the oil filter adapter on your engine, follow the the hose connected to the center fitting, if it goes to the remote filter, then your oil is cooled before the filter, if not, it's vise versa..90nova said:What is the direction of flow,does the oil go to the filter or cooler first?
There`s your first clue. Fram filters are JUNK. But, I doubt that is the sole reason that you`re blowing gaskets out.90nova said:The filter is a Fram
cfm said:What if your 'in' oil line is connected to the out on the remote filter adapter. And say, maybe, the filter has a check valve/anti'drainback valve. Would the filter basically try to stop all the flow and thus creat the extra psi and bust a move?
I dunno, never tried, and never will. But I'd check the oil line routing throughout. This wouldn't be near the first person to mix up oil line routing.
The fitting in the center on the engine adapter is the IN. (filtered) .to the engine, the other off center fitting is OUT from the engine (thats your pressure side from the pump)90nova said:I will try to look for markings,the engine bay is really tight, I had to hang upside down to see the leak at the filter pad on the block.
Great call Scott. I agree here, if the anti-drainback valve has enough strength to hold off say, 50 psi, then there is no place for the oil to go. The oil filter gasket would be the weakest link.cfm said:What if your 'in' oil line is connected to the out on the remote filter adapter. And say, maybe, the filter has a check valve/anti'drainback valve. Would the filter basically try to stop all the flow and thus creat the extra psi and bust a move?
