Well to all that is interested an............ update.
After further research I decided to scratch the alky injection set up for fear of overpowering the drive and possibly the hull. I talked with AO and they said the most hp that has been put behind their hull is around 1200hp which was the quad rotor. Well with the route we were headed we would have been almost twice that. With that said I got spooked. I kind of got carried away with my original goal of going blown for the simple reason of keeping the power in the 900hp neighborhood on pump gas rather than race fuel. So we are going with an intercooled blown carb set up that will run on pump gas. Dyno scheduled for April 1st. The overall plan is to make 1000hp on pump gas and make it dependable with a maintenance plan of 2 to 3 seasons before possible freshening of the valve train. Steve Tanzi from Erson cams designed one cam and Cstraub will design the other cam and we will compare the two on the dyno.
Build specs:
MAX RPM 6500
Merlin 600cid
Lunati pro 4 .50 stroke
Oliver billet 6.385 rods
Venolia custom blower pistons 4.610 / 9:1
Fully ported CNC Pro 1's
2.40int and 1.90exh. avg. flw 418int./cfm and 82% [email protected]
Billet BDS comp 1071 front discharge stripped for gas
BDS comp tented floor intake
830 X 2 Holley blower carbs
Steve Tanzi solid roller
.688/.688 lift - 264int./[email protected] with 115LSA
Cstraub solid roller in the works
CMI big tubes 2 -7/8" primaries with wet tails at the end
Morosso belt drive oil pump
14qt Steffs pan
MSD ignition with Pro billet
Suggestions, comments and or opinions welcome.
Build specs:
MAX RPM 6500
Merlin 600cid
14qt Steffs pan
