1 - 2 of 2 Posts
Hi all,
I was wondering if anyone knew where I could pick up a set of engine hatch hinges? I have a 98 Scarab 29.5 and I removed the engine hatch to pull the engines for a re-power. I've got all but one piece of the hinge. If you have a Scarab, and have an extra set I could use them or more specifically the starboard lower hinge that gets screwed to to transom. These are the hinges that you can pull apart. Any help is as always appreciated. It doesn't help that I just moved to my new house and the hinges were already off the boat. I'm sure it's here somewhere, but my mechanic will be finished with the re-power soon and I wan't to be able to cover the engines while the next step (re-upholstering) is done. Thanks again.
UPDATE: I found some, weren't identical but I modified them to work ;)
1 - 2 of 2 Posts
