I use it every week - it's great.
I put mine in a week before I started the engines this year so the E-Sorb could do it's job on last year's fuel.Fyhr Factor said:I havn't checked if I need it or not, but I got my bottle of E-Zorb the other day from the SW store, just in case I do..
BTW, Thank You ..!! Jeff & Adam..![]()
Thanks for the heads up on that, and it'll still be another week before I can start it up anyway, so I'll throw some in the tank in the morning, I filled the tank & added stabilizer when I winterized it, so if I do have any water, it shouldn't be much..I hope..ghart said:I put mine in a week before I started the engines this year so the E-Sorb could do it's job on last year's fuel.
If you wait until you need it, that means you're going to end up being towed or doing a filter swap out on the water!
I suppose those screw on filters are simple but my water separator filters are located inside the fuel module, real PIA!
I added $300 to the tank today with fresh gas to mix everything up.
Amazing, $300 didn't fill the tank! :laugher:
Good thing I had almost a half tank before I added the gas or it could have been expensive! :blush:
