1 - 16 of 16 Posts
I noticed a fuel leak coming from my carb last Sunday further inspection found it to be coming from where the fuel line connects to carb. I tried tightening but then stripped out the threads on inside of carb :angry1: . Dont know much about carbs so need help first off what part is this. And where can I get it locally.
Discussion Starter · #2 ·
Im pointing at what seems to be a cover, on the inside there are threads from a seperate componet thats what I stripped. How do I replace this?
Also check your local speed and or engine building shops. Any motor head is going to have an old carb laying around. :D
Oh and don't forget to adjust your fuel level after replacing the bowl.
I can't help with the part search because I haven't "been there" ..... yet :rolleyes:
But, My 4150 leaked at the same spot at one time. There was what appeared to be an aluminum washer where the fuel line/nut met the bowl. I replaced it with a nylon washer, and no more leak.
The fuel bowl could be found separately as was mentioned but be sure to get the thin washer/seal that goes behind the fuel inlet fitting.
When it tightens for sealing the large fitting should only make a good compression on the ring and not be a grunting, butt pucker tight. :bigsmile:
Ok now we`re gettin somewhere :). It does have an aluminum washer on it I`ll get a nylon one. I unbolted the bowl from the carb but it doesnt want to come off still I didnt want to force it either. How do I take off the old one?
Use a wooden block or the handle of a hammer and tap progressively till the gasket breaks loose. You will definately need a new bowl gasket too.
Tap in the area toward the end of the bowl where the screws go in, but don't crush anything.
good luck
Like aqua says tap progressivly, and gently, and new gaskets.
BTW ..... Holley makes re-usable gaskets for the bowls. I'm pretty sure Jeggs, Summit, ect., or a local speed shop would have them. They are handy to have ;)
Any time.............this is easy, we are just rattling the keys but you are doing the hard work :bigsmile:
Discussion Starter · #15 ·
Hey Thunderman Im over in West Mich thanks for the offer my local napa guy tracked down a new bowl so Im good to go :D . Gonna through it in this afternoon and make it out to Coast Guard Festival :D
1 - 16 of 16 Posts
