I had this theory about increasing the plenum area of my stock cast iron spreadbore / Quadrajet intake in my 23' 6" '89 Regal Velocity, while insulating the carb. from the transfer heat of the intake. I machined a 1" spacer out of Richlite, located (2) gaskets, longer bolts and studs and installed it. Hopeful it would produce more power, I was cautiously optomistic.
Well today, after a harder start up than usual, (Choke is wired open becasue the choke rod is now 1" too short), my 3 kids, all our gear, cooler and 1/2 tank of gas, (25-30 gals), went for a ride. Couldn't believe it. GPS said 64 mph at 4950 rpm. Last Tuesday I had 3 of us in it and about 1/2 tank of fuel and it was all I could do to run 62 at 4800 rpm. What a difference! One you could feel and see!
Love it when the free stuff and an idea pays off. I'm running (supposedly), a 330 hp 454, that was built on a "Wednesday,
" I guess. I'd recommend this upgrade to anyone looking for a few free hp.
The only other mod I've made was to install a set of Dennis Moore's GLM mans. and risers running through straight pipe, (no mufflers). Going to increase the secondary jetting 2 sizes. I'll let you all know how it responds to the jetting change, as well as the cold ram air induction and "super chilled" fuel delivery system I'm building.
Might just be looking for a bigger prop before it's all over...LMAO
Dave
Dave
