1 - 3 of 3 Posts
Anyone tried them? I will be prop testing all weekend and have a set to try.
Motors make 630hp, 700tq, no boxes, XR drives
Hydro p5 (not the X) 30P box stock...what should I expect?
other are:
28 Maximus labbed and cut to 15.25
30 Maximus that been worked over and are probably a "29"
30 Bravos
30 Bravos (labbed)
32 Bravos that are slightly under pitch
You definately must post your results.
What I've read on the hydro's is that they will tend to run a Formula on it's nose from stern lift instead of bow lift.
I am interested to see what your results are.
Good luck
I have a 33 powerplay that had 500hp's and 28 hydros, this past winter i rebuilt the 500's into 625's and removed the 1" spacer! now the boat not only handles better around the docks but it also rides better (attitude) and has more midrange and better out of the hole! I would not reccomend hydromotives!!!!
1 - 3 of 3 Posts
