1 - 18 of 18 Posts
I want to install some sort of freshwater transom shower, but I want to buy a complete package/kit.
Nothing fancy or with hot water, just a freshwater shower to rinse off and so "she" :p: ok maybe so "we"can wash our hair in the morning
Can you guys point me in the right direction?
I see a bunch, but I want a kit, with pump, tank, wiring, nozzle etc..
Try E-Bay. I sold off all the options my Cobalt came
with since I knew I would never use them. I got less
than .06 on the $. I knew it was dead money but
figured some other boater that needed these things
could use the break.
I'm not really worried about the work part and only want to have a shower to rinse off with, while sitting on the swim step.
I figured they made a tank with pump, and nozzle. just mount it wire it and roll. seems that simple? Doesn't it :confused:
You BLOT that schit!
Seems simple, but I've never seen one.
I can tell you that if you look through some RV parts, it can be inexpensive and fairly easy depending on where you located the tank and pump. Do you have a decent spot to put a 20 gallon tank?
http://www.rvpartsus.com/partsystem/browse-model-parts.pl?type=genr_parts&mr=partnum='868118'&lookup=fullitem&cart_id=2650061d628e3487aec6b3ec3135b47d
http://cgi.ebay.com/ebaymotors/Fres...005QQitemZ150257319452QQrdZ1QQsspagenameZWDVW
http://www.defender.com/product.jsp?path=-1|51|26832|319660&id=589568
http://www.defender.com/product.jsp?path=-1|51|299222|121271|826345&id=961700
Discussion Starter · #13 ·
DEEZT, SATMAN AND GHART all possibles.... I think?
I want fresh water not lake water though. I have a real good spot in the engine compartment already picked out for a tank. Could easily be wired into one of the spare breaker already on the boat. I thought of making a tank, putting a bilge pump in the bottom, installing a hose and hand held shower head. Mount it in, wire it up and roll, but I would like a complete kit of some sort. I'll check out the Rv sites today.
Horse power I would like to see your setup
1 - 18 of 18 Posts
