I have been going out and turning the key on about every hour and the fuel pump kicked on 5 times in a row. Now nothing just a click from this thing. The wires go through a fuse then into this thing and then to the fuel pump.
No corrosion anywhere I think it was coincidence. The second time it happened I unplugged the harness, hit reset buttons, unhooked batteries, unplugged relays, etc, etc and nothing. Then it just decided to kick on. The relay does "click" however every time.Philcat said:The easiest thing to try is replace the fuel pump relay, of course if unplugging and replugging the main harness fixed it before, check your main harness connectors for corrosion.
No, once my pump kicks on it starts and runs fine. Ran it for about 70 miles that day and never missed a lick. It just doesn't kick the fuel pump on every time like it should.Tommygun said:I'm wondering if I'm having the same problem you are. When it quits, does it restart briefly then die? Is it idling rough? What motor? I can't even find the pump on mine- it looks like it's under the oil cooler.
