1 - 3 of 3 Posts
I have a crack in one of my manifold gaskets. I want to replace it myself, is it pretty cut and dry remove manifold pull off old gasket, replace with new gasket, and bolt down the manifold? Is there anything im missing? Any extra tips out there.
If you're taking exhaust manifold, BBC is 20 ft-llbs. I just did both of mine and they are HEAVY. I took off the elbow and riser first to make it a little more managable. If you do take the riser off, make sure you have the right gaskets before you start; not everybody has them in stock.
I think the intake manifold is slightly more, maybe 25 lft-lbs.
1 - 3 of 3 Posts
