1 - 10 of 10 Posts
Hey all,
Its been awhile since I posted, too busy boating or working.
I have a 24' Four Winns Liberator (overweight deep-V). The original motor (350 mag) would spin a 17 pitch quicksilver stainless prop to 4600 rpm.
I built a fairly stout 383 that would spin the same prop above 6000, or a 17 pitch Mirage Plus about the same. The quicksilver would ventilate or spin out above 4800, where the Mirage plus would still dig.
Thanks to a wayward wingnut, I now have one of those Merc 383 MPI motors (350 gross HP, 325 Prop HP). This motor will only spin the quicksilver prop 4100-4200 RPM, and at that level it sounds like it ventilating. The boat still comes out on plane quick, even without the help of the tabs. At first I thought the ECU was rev limiting the engine at that RPM, but I can spin it to +5000 RPM in neutral.
The only thing different with the setup is I added a transom mount seawater pickup. It rides about 1/2" below the bottom of the boat.
Any ideas? I know this motor is about 100HP off of my old 383, but it should blow the doors off the old 350 Mag.
Thanks in advance,
SweetEmotion said:
I didnt know the 241 came with a 350? Seems alittle underpowered to push a 24ft Libby. Why didnt you go with a big block? :confused:
Alpha drive, plus I thought I had another 383 laying around, which was actually junk (cracked crank and block).
Nope, just a single alpha that had a 350 Mag on it when I bought it. It might of originally had a 454/Alpha combo.
Yeah thats true, it would make more sense to swap out the alpha then the 454. Whats ur top speed? Im pushing 61 with my 454mag bravo1
Right now with the 17 pitch only turning 4100RPM its not going over 40.
The old 383 pushed it above 60. The 350 Mag pushed it around 45.
I am very concerned about this, you shouldn't have these problems with a new (now 1 yr old) crate mercruiser engine. 28 hours on it.
Platinum Member
How close to the drive is the pickup? Could be causing cavitation of the prop?
Re: Re: Merc 383 - 4 Winns 24' Liberator Prop Question
This is my best guess too, either that or a fuel pickup issue.
It is a transom mount, mounted about 12" to the right of the gimbal assembly. I will try to grab a pic tonight of it on the lift.
I put it where it looks like on other boats. Should it be level with the hull bottom or even slightly above?
1 - 10 of 10 Posts
