My trim pump is leaking oil and has been for a bit, finally got tired of it and want to fix it for good. Seems the oil is leaking from the seam between the pump motor and the plastic tank. I spent a little time playing with it the other night and saw that it does not fit real tight. Is that normal? Should there be a gasket in there? How does it come off so I can check this out? Does anyone else have this problem????????
Have a good Holiday and thanks for any insight you guys have.:bandit:
