newby to the forums,, so hi to all. Have a 99 larson-226 lxi-5.7/sx volvo-- the boat runs great but one little thing that seems not quite right is the fact of running straight on plane above 20 mph the prop skips out(blows out) when turn the wheel to the left more than a 1/4 turn!!! but turns fine to the right no matter how far at same trim setting.. :confused:
something on bottom of boat on that side disrupting water flow? speedo pickup,depthsounder,etc?
Discussion Starter · #4 · (Edited)
speedo is on right, depth on left as looking at back of boat from behind. mpunted in mirror image location,,didnt use it much last year due to rebuild of floor(rotted when bought) and depth added in early spring. depth mounted in same placement as was on old boat-88 sea ray 186 seville
this still is a posibility,, will remove transducer nexyt outting and let you know
thanks
