Fix It Right!!!!!
Trimman u need to get this to solve that problem once and 4 all. I procrastinated 4 four years but finally spent the $$ 4 it.
Single Bravo, Dual Ram Add-On Hydraulic Steering System
This kit includes:
* (2) Steering Cylinders
* (1) Bravo End Cap
* (2) Bolt Kits
* (1) Bravo End Cap O-ring
* (2) -6 AN X 1/4" 90 Degree Brass Fittings
* (4) -6 AN X 1/4" 90 Degree Stainless Fittings
* (2) -6AN X 1/4" Stainless Tee Fittings
* (4) Braided Stainless Inside Hydraulic Hoses
* (4) Braided Stainless Outside Hydraulic Hoses
* (4) Thru-hull fittings
* (1) Installation Instruction Manual
NOTE: Brazillian steering manifold or Saginaw shuttle valves must be ordered separately.
Installation Instructions for boats using the Brazillian steering manifold or theSaginaw shuttle valve can be found by clicking on their respective links.
The high performance Mayfair by Hardin Marine Hydraulic Steering System is recommended for most sport boat applications. This arrangement gives additional support for even tighter, more firm steering control. Generally speaking, it is recommended to use external power steering on boats which run in excess of 70 MPH, however there are some boats that run 60 MPH that would benefit from the use of external power steering. The new Mayfair by Hardin Marine steering systems use a 316 stainless steel rear cap that is highly polished and is supplied with all stainless fittings, thru-hulls, bolts, and pre-made hydraulic braided stainless lines.
137-9252
$2,175.99
RAM PAGE
hardin marine home page
:wave: :wave: :wave:
