Power Steering Line Source
1119 Views 11 Replies 6 Participants Last post by  Pantera28
I need a power steering hose and both o-rings for the pressure side. Does anyone know where I can get one ASAP???
1 - 12 of 12 Posts
I normally go to The Parkerstore(Triad Fluid Power) or napa. Both of the ones here in town carry a ton of fittings and hose for all types of hydraulics. I would head to the Parkerstore first as they specialize in hydraulics more. Maybe a place to start as they will do it while you wait if they have the ends and so forth.
I had one custom made. Thanks
Try a farm supply or tractor repair shop.
Who made them?
I tried to get a Weatherhead/Aeroquip dealer to make me some and was told that they could not get that fitting end?! :angry1:
opie272 said:
Who made them?
It's a standard fitting nothing special and any power steering service can make them. Even better, the mercruiser will cost you over $100 and I had mine made for $46.00 :D
I ended up doing this.
http://www.jegs.com/i/Aeroquip/023/FCM2608/10002/-1
and then making a standard JIC flared fitting. Problem is the 90 hose end plus this fitting runs the steering hose too close to the exhaust for my liking.
Mine is the same way.
As noted by others above, the local hydraulics supply / service store can make teflon lined stainless braided ones for what the merc ones cost... and can make high quality rubber ones like the merc ones for a good bit less than the merc ones... If you've got a good local shop, orten times they can do them for you in real time...
They made mine while I waited. :D
Ikes brother said:
Did you get an extra line made? ;)
No...........I fixed the problem of where it was bumping up against the exhast manifold.
1 - 12 of 12 Posts
