1 - 4 of 4 Posts
I am considering a new set of labbed props for my boat in hopes of picking up a few MPH for the 1-2 poker runs I plan on doing each year. After playing around with the math, I have an idea on where to start. Keep in mind I am only trying to boost the top end speed.
The current set-up: Bravos @ 1.5 with 24p props turning just a tad over 5200 rpm. This gives me a consistent speed of 70 mph which by my calculation is around 11% slip.
The idea: Move to a labbed 3 blade 25p prop to increase speed. I personally don’t have any experience with labbed props but I hear that they usually spin cleaner which increases your RPMs. Going to a 3 blade should probably do the same. I assume that this will make up for the extra pitch and at least keep me in the same RPM range which would yield a theoretical 3 MPH bump in top end speed. If it was able to spin a little faster and get to 5350 RPM I should be closer to a 5-6 MPH increase. The engines are rated at a max RPM of 5500 – is 5350 running it to fast? Is either of these scenarios even a realistic possibility? These increases are also assuming that I can stay within the same general slip range of 10-12%.
I have experimented with reversing my drives (to turn in) and that takes me from a consistent 70 MPH on GPS up to 73-74 MPH. By reversing the drives and changing the props I could see a theoretical 8-10 MPH increase. If you back that down into reality I would hope to see the top speed in the 75-76 range with both changes and really hope/wish for 77 MPH. Reversing the drives to pull the hull out of the water is also part of my assumption. The idea is that using a 3 blade prop would be fine as I wouldn’t need the extra stern lift generated by the 4 blade. Since I would be changing the set-up for the runs and then putting everything back the way it was, I am willing to live with the slower plane times, poor hole-shot and decreased docking manners while in this set-up. Again, it is only about going a bit faster a few times per year.
Does anyone have an opinion on this non-sense? Is this even remotely realistic? Lots of variables to consider and 5-7 mph (7-10%) seems to be a big jump as I wouldn’t be touching the hp/torque numbers. To this point this has just been a math excercise (which doesn't always pan out in the water) so basically what I am wondering is...... Worth a try or a waste of money? Let's hear some thoughts.
383 Mouse Powered 80.5GPS
I would ask the same questions to Brett @ BBlades or Julie @ ThrottleUp. Matt @ Hydromotive is also very helpful. These people work situations like yours everyday and are experts.
I have had good luck with a labbed revolution plus 4 blade, I would try a 26, the increased rpm from running a rev vs. bravo, and the labbing should let you turn the same rpm with a bigger pitch, but of course run it by brett first, I believe Julie only sells her CNC props now, not sure if she still deals with merc.
Unfortunately Rev4 props only go up to 25 pitch.
MOSCARAB my suggestion is to try and find a set of props to try first and see how your boat reponds. Even if they aren't labbed you will get a good idea of handling and if your boat likes 3 blades.
1 - 4 of 4 Posts
