1 - 8 of 8 Posts
I have a Scarab 7300 lbs boat 31' with two 500hp. When I take off I have to make sure it doesn't rev over 2800 rpm or it will cavitate and spin out. I use a 27" 3 blade mirage. Sould I go to a four or five blade prop to stop the cavitating or will it help the take off? Also is the three blade prop better for speed?
My 30' Sutphen was extremely difficult to get on plane with Mirage props --- it would blow out easily. With 4 blade Bravo props, it would jump right on plane with full throttle, no cavitation.
You definately need to go to 4 blade props.
3-blade props are usually faster but yes a four blade will help with planing, corneringing and have better cruise.
What RPM to do spin the 27 Mirages and are they standard Mirages or Mirage Plus?
The 4 blades will help with your issue and it sounds like we have a similar set-up. I have a set of 4 blades on mine right now and I have no issues getting on plane. I was considering trying a set of 3-blades for a little more top end when I wanted to go out and fly around. For all around use I think the 4 blade is still the way to go.
What WOT speeds are you seeing with the 27p 3 blades and what is your WOT rpm? Might be able to give a suggestion with that info.
Discussion Starter · #5 · (Edited)
The WOT speedo says 85 mph, not sure how accurate that is though, i need a GPS to check it. BUT the RPM reads almost 5000. If I use the 28" 4 blade will I loose 3 to 4 MPH? Your thoughts? The 3 blades are Mirage only.. whats with the Mirage Plus? What is your power plant in your Scarab
A Mirage will ventilate much easier than a Mirage Plus but they are faster on many hulls. The Mirage Plus has more cup and progressive pitch so they stay connected to the water better when planing and cornering.
I would either try a set of 27 Mirage Plus or Bravos. If you go with 28s you will lose a little rpm, if you go with 26s you will gain a little.
I use mirage plus 25" and don't really have a problem unless I mash the throttles (which I never do). I like my plus props. They bite pretty well.
The 27p mirage plus props aren't a bad idea. If you run a labbed set you could get your rpms up to 5200 - 5300 which would have the potential to increase your top speed a few mph and help with your ventilation issue.
If you want to try the 4 blades I would start with the 26p bravo 1s. The 4 blades usually cut a few RPMs from the numbers you see with the 3 blades so with a standard prop I would start by moving down to keep rpms up. If you are willing to spend a few more $ on labbed props you could try the 28p and hopefully you would stay near the same rpms. Assuming you can stay at 5000 with 28s you would probably gain 2 mph assuming slip remains constant.
I am running a pair of 502 HO crates with a few mild upgrades good for about about 485/550 per side. I have a pair of 24p 4 blades on their right now and running 70-72 (GPS) at 5200. The boat has great manners with these props but I am considering a test with 27p labbed 3 blades to see if I can still turn at 5000+ to increase the top speed for a few runs each year. The other option would be to try a set of labbed 26p and go to those permanently. Haven't had time in the last few weeks to think about it much so I haven't decided yet. I did test a set of 25p 3 and got them up to 5300 and had a little room to go. I didn't want to push it and over rev so I went back to the dock figuring that I could go to the 27p 3 blade if it were a labbed prop and stay down in the 5000-5200 range which should be good for 4-6 mph depending on where it lands.
When I was looking around I found a few online slip calculators through google that might be helpful to you if you want to look into it further if you know your gear ratio. If I get around to messing with it more this year I'll let you know how it turned out. Let us know what you decide to do and what rpm/speed results you see.
1 - 8 of 8 Posts
