Question on Alpha drive with 330Hp big block? I have a 1989 250 sport Baja with a big block in it now, with out the out drive. It had a Bravo, but it is long gone (the out drive, Gimbel and transom plate) I have a chance to get a good Alpha out drive with the Gimbel set up for free, but what Alpha drive would I need with this set up? I was told that there is only one Alpha I can use because of the gear ratio. My questions is, will the Alpha Gimbel work with all the Bravo holes in the transom with out cutting or drilling anything? and what Alpha out drive can I use with the big block? if it is just the gear ratio, how can I tell what gear ratio a Alpha out drive has? Also can I use any year Alpha out drive and Gimbel for this set up?
