I would like to see a 2 speed out-drive too, like an over-drive for top speed at peak hp & torque, but it would definitely put more stain on the engine & gears, SO it would also need to have a Variable pitch prop to go with it, but can't see why those engineering problems couldn't be worked out..
They had variable pitch props for aircraft, so why not for a boat too?? then we wouldn't have to mess around finding the just right prop all the time..so if you increase the engines HP, just turn a dial on the dash and go.. :winker:
