1 - 1 of 1 Posts
Two Gen V blocks with 088 rectangle heads roller upgrade.
Here is the best pricing I've found on the web and would offer the order to anyone in the industry who can save me some $$, and actually come through. I've danced with the devil long enough...
Online sources indicate a 3 week backorder on the lifters but the other parts are readily available. Thanks - and I'll post where the order ends up.
Edit - my attachment got blocked:
For Gen V blocks with 088 rect heads. Have Eagle 11111 rotating assemblies installed and need to move with valvetrain. Here's the best $ i've found online, and hope someone in the industry can do a little better for a fellow boater:
CRN-13532-16 Lifters, Hydraulic Roller, Vertical Link Bar, Chevy, Set of 16 $509.95
· Tentative ship date: 2 weeks
CRN-139021 Camshaft, Hydraulic Roller Tappet, Advertised Duration 296/304, Lift .610/.632, Chevy, Big Block, Each $349.95
· Tentative ship date: 6 weeks.
CRN-99098-1 Valve Locks, Machined, Hardened Steel, 7 Degree, 1-Groove, 3/8 in. Valve Stem, Set of 16 $31.88
CRN-99165-1 Cam Button Spacer, Steel, Roller, Chevy, Big Block, Each $11.88
CRN-99955-16 Valve Spring Retainers, Steel, 7 Degree, 1.630 in. Outside Diameter, .635 in. Inside Diameter, Set of 16 $71.88
MAN-11538-8 Valves, Intake, Stainless Steel, 2.190 in. Diameter, Chevy, Big Block, Set of 8. $159.60
·Tentative ship date: 3 weeks.
MAN-11525-8 1.88 Exhaust VALVE Severe Duty $194.00
CRN-99896-2 Valve Springs, Dual, 1.540 in. Outside Diameter, 528 lbs./in. Rate, 1.085 in. Coil Bind Height, Pair--------Summit substitute Comp Cams 953-16 $151.99
__________________
1 - 1 of 1 Posts
