1 - 4 of 4 Posts
Could some one tell me how the speedo works on a Bravo 1 ?
For some strange reason my bilge had around 3 to 4
gallons of water in it, an my MPH gauger stop working.
I'm not sure If water is suppose to flow through this line coming from the drive[black hose] that connect to the [blue] .
Any help will be great
thanks
Steve
Yes water is pushed through the hose from your outdrive to the speedo. There should be a plastic fitting in your drive that attaches to the small rubber hose that goes through your gimble ring.
23concept, thanks for the help :) I now see how this speedo thing works. I'll see if I could put my hands on a brass connector to join the blue an black tubes, and use hose clamps to clamp both sides.
I honestly thought I had one of these again when I saw all that water in the bilge
Ya hopefully it is much easier than that. Has is the boat running with the haul repair/mods, and the new tuning? I have yet to splash mine. Hoping later this week if everything goes as planned.
1 - 4 of 4 Posts
