1 - 15 of 15 Posts
Starboard starter is not engaging at times and now the port starter is beginning to click, click, click when I turn the key. I hit my batt parallel switch and it provides enough power to turn over. My first thought was batteries since the ones in there now are 3 years old and don't seem to hold a charge. So, I replaced them - same issue (clicking). I believe the starboard is a bendix issue, but with both now clicking even with new batts, I'm stumped with what to do. Rebuild the starters or should I be looking at something else?
Don't buy new or rebuild starters without having them tested. Wanna know how I know that.
Check to see where the clicking is coming from. Mine was a small reset button on the front of the motor that was going bad. Don't remember what it is called.
Clicking is a bad solenoid or a bad connection provided that the batteries are fully charged. Not engaging is the starter drive or possibly the solenoid. But there are many other things that can go wrong. I would start at the batteries and work my way down checking or replacing every part and connection. Dont use any auto parts. They are not sealed. I have seen starters full of rust and even cables that looked good that were corroded under the insulation and were very resistive.
I have also seen people replace a lot of parts when it was just a bad cable or poor connection. I always start at the battery and start chasing down drops in power with a voltmeter as I work my way through. Hopefully this is a quick and easy fix once you dive in and start chasing it down.
Since the symptom stayed the same ( like a dead batt) it could indicate what others have said, such as poor connections. Check at your batt switches too.
If all connections seem good then do a voltage drop test. That will tell you if it is a power prob or the component itself.
start with cleaning the battery cable ends, and check ground cable at engine block, these are the two most commcon starter problems I see on a daily basis.
Joe
Discussion Starter · #8 ·
Boomer said:
Certain Gm had a seperate solonoid mounted away fromthe starter. Replace that one.
This particular setup has the starter mounted solenoids plus a smaller solenoid type device mounted on the transom. Is this the one you're thinking of?
Joe
Battery cable ends are in great condition. I'll check the ground cable to rule that out, too. Thanks for the suggestion!
Discussion Starter · #11 ·
Scarab3DMC said:
Mine did the same thing , It was the starters.. found a good place to buy them http://www.db-starter-alternator.com
Great find! Hell, I don't think I could even have them rebuilt for those prices.
However, I cannot locate which model I need. For my 420HP's, Merc shows a P/N 50-808011A05 that superceded P/N 50-17251A3. DB Electrical P/N 6563 looks like it may fit, but the cross-referenced part numbers don't match up.
Any ideas?
Discussion Starter · #13 ·
TRS Drives.
I think I found a match. Looks like their P/N 104-6075 is what I would need. I should have known to look at the most expensive one first! :mad: :eek:
I think I'll research rebuilding, since I know the starboard starter needs it (bendix issue) and chase all the other connections and remedies mentioned here. Plus I'm betting that a rebuild is less than the $158 purchase price.
1 - 15 of 15 Posts
