1 - 3 of 3 Posts
Opening that line will allow the master cyl to drain out. Just drain it and then fill it up after re-connecting.
Open both bleeders at the wheels and keep the tongue up high with a small bottle of brake fluid upside down in the master cyl. It will gravity bleed fairly well that way, then you can pressure bleed after that if you choose.
good luck
good luck
Thanks
1 - 3 of 3 Posts
