Just wondering if anyone has replaced these and remembers what the hose dimensions are so I can pre-order. I want to replace the white rubber/plastic ones on my '91 311 with stainless pieces.
Thanks,
Michael
Now I'm a little confused. I looked at replacement pieces for the cockpit drains, and those use a "3/4" sized thru hull. There's a "5/8" size also but that looks pretty small. I can see the sink drain being the same size as the cockpit drains, but the bilge thru hull has to be bigger. Heh...I just realized I could probably check the hose at the bilge pump right?
