So the question is does anyone know of a supplier that might have a modification to this like Myco uses like the one below that grabs the bow from the sides. Or is the only route to have one manufactured?
I usually have this problem too--sometimes getting OFF as well, it likes to hang up on the bottom roller.djm said:I need the same thing. Not too worried about the bow marks but with my trailer set up the bow hook always gets stuck on the bottom stop and i have to pull the truck up a bit.
Its not slipping, its the back of your boat floating up and the nose sitting on the bow stop, when the transom sits down on the bunks the bow rises up. Try pulling your trailer out some once your boat is winched up as high as you can get it. It should help.Schweitz58 said:I usually have this problem too--sometimes getting OFF as well, it likes to hang up on the bottom roller.
But my biggest problem is slippage...I get the boat on the trailer, winch it up to the stops and ratchet up a safety strap nice and tight too--only to have the boat slip back off the stop about 4" once I'm up in the lot. I'm still wondering if it's really slipping or just an angle-change from the ramp to the level parking lot...
I've resolved to watch more closely next time to see what's going on.![]()
Thanks BTBlack Thunder Struck said:A friend of mine is trying to accomplish the same thing you are with the carpeted v-bunks. He has a 38 Special also.
My Manning has the v-bunk/stop and it loads very nice. Hes a member hear I'll have to give him a ring and see how he is making out.
