IMRON THE ONE AND ONLY :bigsmile:
offshore ginger said:IMRON THE ONE AND ONLY :bigsmile:
guy you do not need a booth , i have a friend who spray's the trailers for skater never has used a booth , clean's the area up real well , wet's the floor down with a hose to settle any dust & good to go . I have to say that the paint that is really nasty is the best stuff overall and will last for ever , like Imron or Awlgrip & to tell you the truth , that is just about what everybody is using. your call :winker:axkiker said:yeah I thoght about imron but that stuff is pretty nasty. Im not sure if I wanna spray that. Especially since I dont have a booth
offshore ginger said:guy you do not need a booth , i have a friend who spray's the trailers for skater never has used a booth , clean's the area up real well , wet's the floor down with a hose to settle any dust & good to go . I have to say that the paint that is really nasty is the best stuff overall and will last for ever , like Imron or Awlgrip & to tell you the truth , that is just about what everybody is using. your call :winker:![]()
:laugher:
Like i said your call . I just got done spraying four drives with Imron and did not see any bird's falling out of the sky . I spray Imron alot and yes it is very toxic and that is why both Awlgrip & Imron are such good paint's . The more toxins, the better the paint :laugher: :laugher: :laugher: Besides you wont die just because you spray it one time :laugher: :laugher:axkiker said:Well I wasnt concerned about not having a booth due to the dirt etc. I was more concerned because I have always heard that stuff is extremly toxic..... I paint all the time without a booth and get pretty good results. I just havent sprayed imron
I just pictured spraying that stuff and seeing birds fall out of the sky. :laugher: :laugher:
offshore ginger said:Like i said your call . I just got done spraying four drives with Imron and did not see any bird's falling out of the sky . I spray Imron alot and yes it is very toxic and that is why both Awlgrip & Imron are such good paint's . The more toxins, the better the paint :laugher: :laugher: :laugher: Besides you wont die just because you spray it one time :laugher: :laugher:
Old Hickory said:If you are concerned about vapors and droplets, roll it on. Awlgrip and Imron can both be rolled. In fact, that has been the prefered method of application for Awlgrip since it's inception. N-95 type(properly fitted) respirator and protective eye wear would be all you need. All the "bad stuff" is being applied to the trailer/boat and not being vaporized into mist by the spray gun. A near perfect and more durable finish can be had by rolling.
Hick
Awlgrip is more durable , put if you can spray , SPRAY ........... and might i say TOXIN'S are TOXIN'S rolling the paint , brushing , (tipping ) or spraying it.................. I always paint bilge's in Imron by brush . G .G . :winker:axkiker said:now I really like the idea of rolling.............
I didnt have any idea you could roll on imron....
any preference on allgrip. Im not familiar with it. how does it compair to imron
