ebay....around $70 for both limit & sender..... The cheapest I've found anyways for REAL merc parts
Be careful with that, if you over trim while running, you will blow the U-Joints, and maybe more.Super24 said:As long as you have everything apart I would consider switching to a mechanical indicator. It might cost a little more, but you probably will never have issues with it again.
Also, I would loose the limiter. My boat is rigged where the trim switch moves the drive the complete up and down range. I don't see a need for a "trailer" switch.
RCHEVELLE71 said:Be careful with that, if you over trim while running, you will blow the U-Joints, and maybe more.
