1 - 20 of 24 Posts
Tetra moly is the best automotive grease for extreme pressure but it doesn't have the water resisting abilities that marine grease does.
You can use auto grease if you want to but that would be a compromise of protection for your boat; it is auto :winker:
I have two grease guns hanging in the shop. One is auto and one is marine. Gotta have both. :bigsmile:
goebel1 said:
aquaforce said:
I have two grease guns hanging in the shop. One is auto and one is marine. Gotta have both. :bigsmile: [/QUOTE
I will be a proud owner of two also :laugher: :laugher: :laugher: ]
Great :bigsmile:
Definately don't want to shortcut the protection for the boat. Some do, I don't.
Correct, you do NOT want to use 2-4-C lube foe U-joints & the gimbal bearing, that's for everything else, pivot points, steering, etc..
What you need to use is Mercury Universal Joint & Gimbal Bearing Grease, Part # 92-802871A 1
Discussion Starter · #10 ·
Thanks you Sir for clearing that up.
383 Mouse Powered 80.5GPS
I've been using 24C for everything including all the above since 84 on the Challenger. Gimball bearing is original and turns great. No need for replacing it. Also use it for the bearings on my trailer which are also original. It might say not to use it but I have proof it works just fine.
That's very interesting Ryan, I'm glad it worked for you, and if Mercury recommended I could use it, I would...but they don't, so I won't...
It does state on the 2-4-C tube that it's fine for trailer wheel bearings,, it is a great water resistant grease...so that makes sense...
Just curious what your reasoning was for using it on the U-joints and gimbal bearing???
No problem, I can understand the need to be sure..that's the way I am too..
When you get the grease, it'll say right on the tubes what it's good for, I use the small 3.5 oz tubes, usually comes in 3 packs, only because I have a small grease gun just for the boat, but it's available in the larger tubes too.
Do you have a Mercury Parts dealer/store near you?? they usually have all this stuff on the shelf, they may charge a little more, but you don't have to wait or pay for shipping either.. Just a thought.. :)
Discussion Starter · #17 ·
I live in a small town and it is 48 miles to the next big town that why I have to order everything
Discussion Starter · #18 ·
Do you work for a Mercury Parts dealer
That's quite a trip, no wonder you have to order things, shipping cost is a bargain then, compared to the fuel to get you there and back.
And no, I don't work for Mercury dealer.. If I did, I'd give ya a deal... :winker:
Really had no reasoning other than I had and still have 50 tubes in the garage. :D It is a very good water resistent grease.
1 - 20 of 24 Posts
