1 - 12 of 12 Posts
Aggressor Tom said:
everytime I run with Matt he is getting closer and closer to passing me. :D The ITS just might do it.
Definitely get some more bow lift. I'd feel alot more comfortable with the hydraulic steering too....
I can always pass you at the gas dock! :laugher:
RSCHAP1 said:
Doesn't the ITS incorporate hydraulic steering also?
Latest POS HotBoat mag did an "article" (if you can call it that) on 50' Hustler. Said 700s with ITS. Then says Latham hyd steering? :confused:
Yes, ITS (Integrated Transom System) incorporates hydraulic steering rams. Makes for a very cleam transom.
I put a ITS gimble ring and bell housing on my old Advantage. Bolted right up to the bravo transom assy and a bravo drive bolts right up to that. I have no idea about the steering. I removed that part of the gimble ring. The ITS gimble ring is a HD gimble ring and you cannot use trim senders anymore.
1 - 12 of 12 Posts
