What carb is on it?
The Quadrajet is prone to the fuel "boiling" out and flooding the intake with raw fuel after the engine is warmed up and then shut down. So it might be OK just as is.
The choke might be set too rich and needs a slight adjustment.
Remove the flame arrestor and look at the choke when the water temp is almost at "normal' reading.
It should be wide open.
