if your boat trailer has DEXTER AXLES under it check the axle housing to see if you have holes drilled at the 3 o'clock or 9 o'clock position on the housing! if you do you have a problem as i do with water standing in the housing. it is rusting the inside because it cannot escape!my trailer is under warranty but the trl. manufacture tells me to drill holes in the bottom of the housing, but the warranty will be voided if i do this! this will let the water out,but the damage is already done to the inside of the axle housings!dexter axle is located in elkhart ,indiana and they ship these axles all over the country. they have not responded to my-emails or my phone calls. voice mail!if you have this situation you will notice thick rusty substance on your axles and the underside of your trailer!! bill
