A buddy of mine works for a fuel company and has a paste that you dip in your fuel tank to check for water (boat has been cutting out when getting out of the water). What's the best way to gain entry into your fuel tank? Thanks.
Access is best acheived by removing the fuel level sender. It should be a round piece with 6-8 screws around the outside. Remove the screws and lift out the sender. You might want to replace the gasket while you have it apart.
Powerboat Forums at SpeedWake
