wellcraft 233 eclipse
19K views 44 replies 19 participants last post by  BoinkSwag000
hello to all. i am looking for some feedback. i have found a 1991 wellcraft 233 eclipse. i can get it for $1500 with a trailer. the boat needs some minor work and a lot of tlc. are there any problem areas to be on the lookout for?
thanks,
john
#3 ·
None that I know of that is just becuase of the brand...
You have to look for the obvious if the boat has been neglected for too long... There is usually reasons why things are so cheap, I am sure you know that.
Check the motor, run it, check the drive, and knock on the hull and listen for dullness or soft spots, pull off the bearing buddies on the trailer to check for rust, etc, check rollers/bunks... lots of things to look for... but it is a cheap thing...
#4 ·
Check the srtrngers in the engine area around the motor mounts, mine was very poorly sealed from the factory, and had some rot, the floors were also replaces in mine before I got it, other than that, it was a very nice boat for what it was, mine was a 1992 232 eclipse bowrider with the midcabin, chevy 350, and alpha drive. I added thru hiull exhaust, but it was difficult to get it below the platform(which my wife loved for hanging out on), so I ran them over. Also, it is a fairly shallow deadrise(vee), do it rides a little rough, but does ok on speed(close to 50 with a stock 350, and bottom paint).
Rick
#15 ·
Wow, great project. Can't wait to see how it comes out. Best of luck!!
I had a 1984 Wellcraft 210 Cuddy with 350/260hp. I absolutely loved that boat. Very nice riding for the size. Plus it had a cooler built in the floor. Genius. :D
