1 - 11 of 11 Posts
cubicinches said:
I believe the Canfield head requires a 3/4" reach gasket seat plug. Those plugs are .460 reach tapered seat.
You are correct.
Canfield suggests a baseline plug is the Autolite 3924's.
BKR6E or BKR7E's (NGK V Power) should work out fine. 7's are colder than 6's.
FYI: You must read'm to know what heat range to ultimately use.
Gap to .040" and run'm.
Crap,,,, I missed the head upgrade !!!!!
ok,,, A/C LTS !!!!
cfm said:
You are correct.
Agreed... The 3924 is a bit hot for the blower application. If using the NGK, I'd start with the 7's.
1 - 11 of 11 Posts
