I say 63 mph GPS
What's your RPMs?dieselmatt1 said:im only seeing 52 on gps ? is that right
That's 26% slip! Something is not right. With 12% you would be in line with what the others are saying.dieselmatt1 said:4600
I thought the same thing about Odd/even Pitchs, but I think Julie at T Up corrected me once upon a time.Super24 said:That's 26% slip! Something is not right. With 12% you would be in line with what the others are saying.
24 pitch 3 blade? I thought they came in odd numbers. Did somebody "lab" it?
You may want to try a 23 or 25 P Mirage Plus 3 Blade. You really are not even in the power range. I believe the operating range is 4800 - 5200. My 95 24 Outlaw did not like the Bravo props so I ended up with the Mirage Plus.dieselmatt1 said:im only seeing 52 on gps ? is that right
I assume you mean a 23 pitch prop on a Bravo drive? Bravo props are 4-blade and stamped even numbered pitches.dieselmatt1 said:you guys are right its a 23 pitch, bravo prop
