I want to update the rims and tires on my trailer.....
I hate them with a passion!!!!!
:devious:
:devious:
Goodyear Marathons!!!LiquidFire said:I want to update the rims and tires on my trailer.....
I just bought a brand new set of 5 of the Carlisle tires last fall. Price was decent and I guess that is what atracted me to them Also, I got the exact replacement tire that was on the trailer. Did I make a wrong desision? I don't trailer far, but I frequently trailer. About 10 miles one way to the water.BajaIceBreaker said:Word of advice to everyone out there... do yourself a favor and NEVER PUT CARLISLE TIRES ON YOUR TRAILER!!!!! I can't stress this enough. They are the cheapest tires out there and for good reason. .
You are absolutely correct... for many boats. Although a squating tow vehicle isn't good for anything, it actually only affects a trailer that has torsion springs. My trailer, and many many other trailers have leaf springs and load equalizers. The equalizers are mounted between the axle's to the leaf springs of both axles. They eliminate the problem of more weight on one axle than another. But in any instance, a squating tow vehicle usually rsults in increased sway, therefore causing excess wear on the trailer tires.Canada Jeff said:Thats good advice Baja.....
Another item to check is keeping the trailer as level as posible. Adjust the hitch reciever acordingly. I see to many trailers being pulled with the nose down because the truck drops with the weight. This puts more weight on the front axle, instead of evenly over the two.
