After attending my last class at Merc, three months ago, I would not trust it at all. What a bunch of hype! “This system is to merely extend the boating season into freezing weather, it is not a replacement for proper lay-up. ” Don’t think that you will see any warrantee help if anything freezes. If you are not going to run glycol through the system I would pull the hoses off the manifolds as well as pulling the blue plugs. There are check valves that keep hot water from the manifolds from back flowing to the fuel cooler causing heat soak related problems in the fuel system. Thank you high compartment temps and poor fuel. Students complained of grasses and salt build up in the check valves. That is what I learned about that. With the revised firing order and SPFI, the 496 is a smooth runner. Nice engine. Any fuel injected engine, outboards included, should be stored with a mixture of 5gal quality fuel 64oz quality 2 cycle oil, and double the amount of fuel stabilizer. It all fits into a portable 6 gallon outboard tank with a primer bulb. This will lubricate the injectors, fuel pump, and regulator. I run them for 10 minutes. Merc says 5 min for yours. Don’t fill your new filter, as you will be able to prime the system fuel of the mix with the primer bulb. You can get by not doing this but you’ll eventually get bit. The tolerances are much tighter than a carb! And a news flash for all with electric fuel pumps. When recommissioning for the season or commissioning new product Merc is recommending that the boats fuel system be primed with a bulb to prevent the pump from running dry at all. Testing has shown that 45 seconds running dry does damage. These vane type pumps don’t prime too well as it is. Good luck.
