575 SCi motors
1 reading
14K views 40 replies 14 participants last post by  BillR
Who on here has experience with these motors? I am looking at a boat with 2001 stock 575SCi's. The motors have about 150 hours on them and appear to be clean and well maintained.
Is there anything I should watch out for with these or are they relatively trouble-free like the 500EFI's?
Does anyone have experience with the Az speed and marine ECU reprogramming with the 575's?
#2 ·
BillR has them in his Top Gun which he recently purchased with about the same number of hours. He loves his engines and they have not missed a beat.
Merc deliberately goes easy on the engines keeping the boost low for reliability. The easiest performance upgrade is to install a whipple intercooler under the blowerw and voila you have another 25 to 40 hp. The whipple intercooler is the same height as the stock intake manifold.
they are great engines!
#8 ·
so what's a little maintenace on your baby....go for the blowers...
talk about disappointed - karen and I were at Ocean Performance few weeks ago looking at Cigs and OL's and they had a 42 OL in the showroom with triple HP 525 EFI's - yes, they're sweet but in a boat like that I want to see BLOWER MOTORS!!!!!!!!
#9 ·
Yes they are awesome! They will use about 10% more fuel.
The thing to look for is to make sure the seals on the blower pulley's are not leaking oil. Early models had issues with bad seals. Check the repair history, it is likely that they have been replaced. Also have compression and leakdown test done.
So far they appear to be a rock solid turn key motor. Only extra maintenance is to change blower oil about every 50 - 100 hours. "I" plan to change oil around 25 hours as they do run rich.
Once you run these, you'll be hooked. I was VERY skeptical about blower motors, but since this is a very mild Merc engineered package; I am now comfortable.
Also, Scott Buteyn of Mercury Racing was here checking out Nauti-Props boat and doing some field testing. I got to spend quite a few hours talking with Scott about the 575 (and others) and any issues that Merc may have experienced with it. Basically it is a VERY sound motor. Scott said that head gaskets should be replaced about every two years and "check" valve springs about 300 - 400 hours.
Go for it, you'll be glad you did.
#10 · (Edited)
Bill,
How much boost do they put out, and at what RPM do your motors idle at?
#12 ·
Adding a cooler will not make more hp. It will allow you to up the boost to make more hp safer, as it cools the intake air that is now hotter after being compressed to gain more boost reducing the fear of detonation. The whipple cooler is not very high, which should install w/o having to raise your engine hatch.
#14 ·
OK this contradicts what Speedwake said...who is correct? OR both are?
#15 ·
I am-without a doubt.
The more boost the more heat generated by the blower and higher induction air temps. It can get so hot entering the cyl that it will detonate-like a diesel-before the spark plug fires. This is your major engine damge.
Also, we know that cooler air is more dense than hot air, therefore-you can pack more air in the cyl if it is cool-getting more power if you have the correct fuel ratio.
With no other changes to a blower motor that is being correctly fueled and cooled-the addition of a chiller will not make more power. It will allow your engine to make the same amount of power it currently does, over a longer wot run. This is because you engine at wot slowly makes more heat-heating the intake and the blower is also generating more heat, causing a loss in hp. The chiller maintains your original power over a long wot run.
Now add the chiller and you can up the boost, add the needed more fuel and a timing change and you can get the hp increase we all desire. :bigsmile:
