It,s been a long time coming but finally got the boat done. I have a pair of 468's w/Rec port heads, Merlin intake, SRP 10 to 1 pistons. 850 Holley, MSD ignition and Crane FTH cam 534, 553 (.050 226/236) 112 lobe. Put new Bravo Transom assemblies and used 2000 1.5 gear ratio Bravo drives w/nose cones and 24 Bravo one Props spinning out. I had put full hydraulic external steering and increased my trim tab length by 4"(Bennet dual ram). Put the boat in this week end it ran 70.2 GPS at 5250 rpm what a disappointment.
I feel that my exhaust and the extra length on my tabs are holding me back. I had ran out of money and had to go with a homemade exhaust setup. They are GLM cast manifolds with Gil small block dry pipes 3.5" OD (now wet pipes) that I modified to fit. Going with that I no was going to hurt my HP but it only cost me a total of $725.00 for both engines compared to $4000.00 for Stainless Marine. I will try my hand an making Headers on day.
The tabs only come up to level with the haul not like K-planes that come up to negative. They seem to drag in the water more than before, hence scrubbing of speed.
I think I will put the tabs back the way they were and tune the carb a bit more and see what this weekend brings. Hopefully 1 to 2 mph more.
All yea thanks for the help with the gear ratio, 1.5 is where I need to be.
