technical/hypothetical question:
Assume you are towing a gooseneck/5th wheel trailer in the 15K lb range with a 1 ton truck. I have read recommended tongue weight is 20-25% of the total trailer/cargo weight. Assume you are below the 20-25% tongue weight (3000-3750lbs)....say in the 10-15% (1500-2250lbs ) range. How will this effect the handling of the tow vehicle?
I'm assuming the percentage recommendation is higher on a gooseneck trailer simply because of the additional load capacity offered by centering the tongue load over the rear axle, verses cantilevering the load behind the axle ( bumper hitch ). I understand how a light or negative tongue load can effect a bumper pull trailer/tow vehicle combo. I'm sure this can also happen with a gooseneck. I'm just curious how much load you MUST have on the tow vehicle to be safe.
