Tried following the manual and put the 2 stroke oil in the water seperating fuel filter per the owner's manual, then tried running the boat at idle. It says that the engine is supposed to start smoking, then you shut it off. It will not smoke no matter what I do. I've tried changing the ratio of gas/oil in the filter, I think one time even filled it all the way up with oil. Nadda. And I've let it run for like 5 minutes at least, with no change. This year I wanted to run antifreeze through the motor as well, so even if I do get it to work, the timing will be a pain. Should I just pull the plugs and spray fogging oil into each cylinder while turning the engine over?
